I am trying to compile a simple test program using the source code of MQX. First, I had errors stating:
#if (!MQX_USE_IPC) && (! defined (MQX_DISABLE_CONFIG_CHECK))
#error IPC component is currently disabled in MQX kernel. Please set MQX_USE_IPC to 1 in user_config.h and recompile kernel.
#endif
and
#if (! MQX_USE_TIMER) && (! defined (MQX_DISABLE_CONFIG_CHECK))
#error TIMER component is currently disabled in MQX kernel. Please set MQX_USE_TIMER to 1 in user_config.h and recompile kernel.
#endif
1) The MQX_USE_TIMER and MQX_USE_IPC are not in user_config.h but rather small_ram_config.h
2) When I define them as 1
i.e.
#ifndef MQX_USE_IPC
#define MQX_USE_IPC 1
#endif
#ifndef MQX_USE_TIMER
#define MQX_USE_TIMER 1
#endif
I get the following error.
Error : 'MY_IPC_ID' is not a member of class 'struct kernel_data_struct'
mqxiinit.c line 94 kernel_data->MY_IPC_ID = BUILD_TASKID(kernel_data->PROCESSOR_NUMBER, 1);
The code is:
/* Set IPC id for compatibility */
#if MQX_USE_IPC
#endif
Any hints?
S
Solved! Go to Solution.
you also need MQX_IS_MULTI_PROCESSOR set to 1 in user_config.h.
PetrM
PetrM
Did IAR support IPC debugging?
My K60 always got exception after seting kernel_data->CONFIG2 = MQX_CNFG2;
What's wrong?
Jack
I addresed the issue.
For the 3.8 version, the BSP_DEFAULT_START_OF_KERNEL_MEMORY defined the kernel_data at user level, which make the compiler allocate kernel_data before the MQX itself defined the pointer. So the kernel_data pointer is wrong and cause the ipc error.
