k64f hallo example no com port found
1,114 次查看
niklasroth
I have a frdm-k64f board. I just wanted to try out the mqx hello world example. I drag and droped the hello_frdmk64f.wsd into my cw10.6 workspace. I pluged in the usb connector into the K64F USB connector, over which the board is supplied and is communicating.
After compiling that project (debug mode) pressing the build (hammer), I press "Debug" to download and start the applicaiton. Then I open a Termite to connect to a com-port but unfortunatelly no com-port appears!? What did I do wrong? Do I need to install a special driver usb to serial driver?
My system:
Windows 7
cw10.6
mqx4.2
greets nik
892 次查看
Hello Niklas,
Please connect the USB to  OpenSDA (J26 pin ) port on FRDM-K64 , and configure the terminal to
115200 baud, 8 data bits, 1 stop bit, no parity
If it still can not work , please tell me which version of MQX  。
Hope it helps
Alice
893 次查看
Hello Niklas,
Hope it helps
Alice
892 次查看
niklasroth
I tried that before but it didn't work. Then I changed the serial monitor software and it worked. "Termite" didn't received any messages but "putty" worked pretty well :-)
Thx for helping!!
