I am trying to use an external SPI flash to store my web page data on a TWRMCF52259.
I have the SPI FLASH working using the BSP's spi0 and MQX fopen ("spi0:", NULL)
I can read, write, and erase the flash using this method.
I am trying now to install an io driver so I can layer on part manager and MFS and I am getting an error when I build with the _io_dev_install
This is my code that gets the error:
_mqx_uint _io_webflash_install(
char_ptr identifier)
_mqx_uint result;
result = _io_dev_install(identifier,
_io_webflash_open,
_io_webflash_close,
_io_webflash_read,
_io_webflash_write,
_io_webflash_ioctl,
NULL);
return result;
This is the Error I am getting, and have not been able to solve it with anything I have tried.
>illegal implicit conversion from '__regabi long (struct mqx_file *, unsigned
>char *, long)' to
>'__regabi long (*)(struct mqx_file *, char *, long)'
Does anyony have any ideas?
Thanks for reading
已解决! 转到解答。
Hallo JKadin,
check function prototypes of your _io_webflash_read and _io_webflash_write functions.
It should be
_mqx_int _io_webflash_read(MQX_FILE_PTR, char_ptr, _mqx_int)
Hallo JKadin,
It should be
You were exactly right.
For anyone else looking at this and if I need it again.
memory_write_data was defined as:
uint_32 memory_write_data (MQX_FILE_PTR spifd, uint_32 addr, uint_32 size, uchar_ptr data)
so
__io_webflash_write was declared as:
_mqx_int __io_webflash_write
FILE_PTR fd_ptr,
uchar_ptr data_ptr,
_mqx_int num
IO_DEVICE_STRUCT_PTR io_dev_ptr = fd_ptr->DEV_PTR;
WEB_FLASH_STRUCT_PTR handle_ptr = (WEB_FLASH_STRUCT_PTR)io_dev_ptr->DRIVER_INIT_PTR;
_mqx_uint result;
uint_32 w_addr;
w_addr = handle_ptr->addr;
result = memory_write_data (fd_ptr, w_addr, (uint_32)num, data_ptr);
if(result == num)
return(MQX_OK);
else
return(IO_ERROR);
to be clear data_ptr was declared as uchar_ptr because declaring it as a char_ptr caused an error in the call to memory_write_data(). When data_ptr was declared as uchar_ptr the error at memory_write_data went away, and since _io_dev_install was not written yet, that error did not appear ... yet
The way to fix this is to declare data_ptr as a char_ptr to satisfy _io_dev_install() and cast data_ptr to a uchar_ptr in the call to memory_write_data() like so:
memory_write_data (fd_ptr, w_addr, (uint_32)num, (uchar_ptr)data_ptr)
