where can I download MQX 3.8.0. In other subject, introduced downloading through the following URL(www.nxp.com/mqx), but I can't fine the download interface. Thank you.
Hi @jgeSHV :
MQX v3.x/v4.x is no longer available & superseded by MQX v5. please refer to below link for more details
Also, MQX 3.8 is very old, the latest free MQX version is v4.2. why do you need MQX 3.8?
Hi Daniel,
Thanks for your reply.
(Device:MK60FN1M0VLQ12, IDE:CW for MCU 11.1, MQX: FSLMQXOS_4_1_1_GA)
When compiling the code, I found that some files could not be found, the warnings information is as follows. Is there a version mismatch of MQX, or do you have any suggestions? Looking for ward to your reply.
Invalid project path: Include path not found (C:\svn\projects\Standard_MQX4_Source\mqx\source\io\io_n25flash). bsp_twrk60f120m pathentry Path Entry Problem
Invalid project path: Include path not found (C:\svn\projects\Standard_MQX4_Source\mqx\source\io\crc). usbh_twrk60f120m pathentry Path Entry Problem
Invalid project path: Include path not found (C:\svn\projects\Standard_MQX4_Source\mqx\source\io\io_dun). usbh_twrk60f120m pathentry Path Entry Problem
Invalid project path: Include path not found (C:\svn\projects\Standard_MQX4_Source\mqx\source\io\io_at24mac402). bsp_twrk60f120m pathentry Path Entry Problem...
I would suggest you install MQX package into the default location. c:\Freescale_MQX_4_1
