Unable to use the plugin \"ColdFire RTOS debugger\". No valid license key was found.
969件の閲覧回数
chris2012
I have a licensed professional version of CW10.2.
I have just installed MQX which is supposed to be free. Why do I get this when I try to debug?
Failed to resume target process., Unable to use the plugin \"ColdFire RTOS debugger\". No valid license key was found.
564件の閲覧回数
c0170
Senior Contributor III
Hello Chris Stuart,
this seems to be your case, have you tried to follow this steps to resolve your issue?
http://www.freescale.com/infocenter/index.jsp?topic=%2Fcom.freescale.doc.mcu.faq_guide%2Fdoc%2F030_I...
Let us know if it helps.
MartinK
4 返答(返信)
564件の閲覧回数
chris2012
Yes.
Under Help>Freescale licenses:
Product: MCU Wizard and Tools Plugins
Version: 10.2.0.FSL_b03041
Status: Activated
It is a hardware key-based license. It uses a USB dongle and I'm running on Windows 7. I know initially I was told that the USB dongle licenses had a problem with Windows 7, but then I was told by someone else at Freescale that it had been fixed with CW 10xx
564件の閲覧回数
chris2012
Thanks. Selecting "None" under Task Aware Debugging worked. Do I need a seperate license for that?
564件の閲覧回数
c0170
Hello Chris,
Is your CW10.2 licensed? Check on toolbar Help -> Freescale Licenses.
If you need any more assistance, ask in CW section. It might be answered faster for this matter.
MartinK
565件の閲覧回数
c0170
Hello Chris Stuart,
MartinK
