Socket not receiving data after shutdown and creation
1,266 次查看
Mohsin455
Hi All,
           I am using MQX 3.8 and TWRK60N512. I am receiving data from multicast address and it works fine. The issues is once I shutdown a socket and open it again, I am not able to receive any data. Below is the code I  have used for shutting down and reopening the socket. Is there anything else required after shutting down the socket ?
 /*  ** Send an DROP MEMBERSHIP message via setsockopt  */ errcode = setsockopt(rx_sock, SOL_IGMP, RTCS_SO_IGMP_DROP_MEMBERSHIP, &mc_req, sizeof(mc_req));  if (errcode != RTCS_OK) {  printf("error");  _task_block(); }  /*  ** Shutdown the existing socket  */ errcode = shutdown(rx_sock, 0); if (errcode != RTCS_OK) {  printf("error");     _task_block(); }  /*  ** Create socket to join multicast group on  */ rx_sock = socket(PF_INET, SOCK_DGRAM, 0);  if (rx_sock == RTCS_SOCKET_ERROR) {  printf("error");     _task_block(); }  /*  ** Construct a multicast address structure  */ memset(&rx_addr, 0, sizeof(rx_addr)); rx_addr.sin_family      = AF_INET; rx_addr.sin_addr.s_addr = INADDR_ANY; rx_addr.sin_port        = port;   /*  ** Bind to multicast address to socket  */ errcode = bind(rx_sock, &rx_addr, sizeof(rx_addr)); if (errcode != RTCS_OK) {  printf("error");     _task_block(); }  /*  ** Construct an IGMP join request structure  */ mc_req.imr_multiaddr.s_addr = multicast_address; mc_req.imr_interface.s_addr = ip_address;  /*  ** Send an ADD MEMBERSHIP message via setsockopt  */ errcode = setsockopt(rx_sock, SOL_IGMP, RTCS_SO_IGMP_ADD_MEMBERSHIP, &mc_req, sizeof(mc_req));   if (errcode != RTCS_OK) {  printf("error");     _task_block(); }
Mohsin455
标记 (1)
4 回复数
483 次查看
Mohsin455
Hi All,
             Can anyone please confirm if the procedure for closing and reopening the socket is correct ?
Mohsin455
483 次查看
Luis_Garabo
Hi Syed,
Have you tested by adding the FLAG_ABORT_CONNECTION flag?
The value for it is:
#define FLAG_ABORT_CONNECTION (0x0010)
I do it in this code and it works all the time:
while(TRUE)
  sock = socket(AF_INET, SOCK_DGRAM, 0);
  if (sock == RTCS_SOCKET_ERROR)
   printf("\nError, socket create failed");
   return;
  memset((char *) &local_sin, 0, sizeof(local_sin));
  local_sin.sin_family = AF_INET;
  local_sin.sin_port = SERVER_BROADCAST_PORT;
  local_sin.sin_addr.s_addr = INADDR_ANY;
  result = bind(sock, &local_sin, sizeof (sockaddr_in));
  if (result != RTCS_OK)
   printf("\nError, bind() failed with error code %lx", result);
  memset((char *) &remote_sin, 0, sizeof(sockaddr_in));
  remote_sin.sin_family = AF_INET;
  remote_sin.sin_port = SERVER_BROADCAST_PORT;
  remote_sin.sin_addr.s_addr = INADDR_BROADCAST;
  ipcfg_get_ip(BSP_DEFAULT_ENET_DEVICE, &MyIP_data);
  //printf("\nIP Address      : %d.%d.%d.%d\n",IPBYTES(MyIP_data.ip));
  snprintf(myBuffer, 50, "ServerForAndroid %x\n", (uint_32)MyIP_data.ip);
  printf("%s",myBuffer);
  //count = sendto(sock, my_buffer, 11, 0, &remote_sin, sizeof(sockaddr_in));
  count = sendto(sock, myBuffer, sizeof (myBuffer), 0, &remote_sin, sizeof(sockaddr_in));
  if (count == RTCS_ERROR)
   printf("\nsendto() failed with error %lx\n", RTCS_geterror(sock));
  else
   printf("\nSent %ld bytes of data.", count);
  shutdown(sock, FLAG_ABORT_CONNECTION);
  _time_delay(1000);
I hope this helps you.
-Garabo
483 次查看
netra
Diag accept() failed, error 0x1704
InitDiagSocket: Created the stream socket 536899428
Failed to bind the diag stream socket - 0x1633
diag listen() failed - 0x1704
I am receiving above error after shutting down socket using shutdown() and creating again the socket.
483 次查看
Luis_Garabo
These are the error you are getting:
TCSERR_SOCK_INVALID (RTCS_ERROR_BASE|0x704)
RTCSERR_TCP_ADDR_IN_USE (RTCS_ERROR_BASE|0x633)
Perhaps you are getting out of resources. Make sure you are giving enough memory to the RTCS. Try this in oyour code before creating the RTCS stack:
_RTCSTASK_stacksize = 3000;
I hope this helps.
-Garabo
