SNTP_oneshot mistakenly return RTCS_OK
Search instead for
shaozhongliangs
MQX 4.2
I think I found a bug in SNTP_oneshot().  By accident SNTP_oneshot() returns RTCS_OK while NTP server is not reachable.
If the TPC/IP is very busy, the select function will return RTCS_ERROR because RTCSCMD_issue can't alloc a message from queue pool. Then the err is not zero, it causes a wrong RTCS_OK return value.
static uint32_t  SNTP_timed_send_recv
      uint32_t sock,
         /*[IN] socket */
      _ip_address  *destination,
         /*[IN] remote IP NTP service */
      uint32_t  *msec_count_ptr
         /*[IN] millisecond timeout value */
{ /* Body */
   /* Accept only correct replies */
   do  {
      RTCS_FD_ZERO(&rfds);
      RTCS_FD_SET(sock, &rfds);
      err = select(1, &rfds, NULL, NULL, timeout);
      if(RTCS_ERROR ==  err)
          break;
   } while (msec_count > 0);
   *msec_count_ptr = msec_count;
   if (err == 0) {
      error_code = RTCSERR_TIMEOUT;
   } else  {
      error_code = RTCS_OK;
   } /* Endif */
   return error_code;
} /* Endbody */
Tags (3)
danielchen
Hi S.z:
Thanks you for your feedback. I would suggest you change 'break' to 'continue', this maybe fix this issue.
danielchen
Hi S.z:
