I am working with CodeWarrior v10.6 and MQX v4.0.
I am following security_email demo and getting the time from time.nis.gov. I am getting date time properly with UDP port 37.
Now query is default time on MQX is from 01/01/1970 and default time of time.nis.gov is from 01/01/1900. If both have a different default Year How I am getting a proper Current time?? There should be 70 year deference as per my knowledge.
Can anybody tell me how SNTP working in detail?? There is only sntp_oneshot and sntp_inti function available in rtcs library. No more detail I got.
Solved! Go to Solution.
Hi Utsavi,
Attached ZIP has example code to manually or automatically or set default time based on last compile time of application.
I last tested about a year ago on TWR-K70F120M tower kit. Ignore the SSL stuff.
Hope it helps.
David
Hi David,
Thanx for reply.
