Reading GPIO output state
Search instead for
dan_quist
Does MQX support reading the the state of an ouput GPIO pin? Of course I can keep track manually which pins are set or not, but I find it surprising that there's not a method to do this through the GPIO driver.
Maybe I'm missing something? I tried GPIO_IOCTL_READ, but that command is only valid for input pins.
KJFPE
What I did on the K60 tower system to read a button I used lwgpio_get_value
// Setup the button
if (!lwgpio_init(&btn1, BSP_BUTTON1, LWGPIO_DIR_INPUT, LWGPIO_VALUE_NOCHANGE))
DEBUG_OUT("Initializing button GPIO as input failed.\n");
lwgpio_set_functionality(&btn1, BSP_BUTTON1_MUX_GPIO);
lwgpio_set_attribute(&btn1, LWGPIO_ATTR_PULL_UP, LWGPIO_AVAL_ENABLE);
// Then some where else you can now read the state of the button
/* Read Switch */
int_16 Read ()
int_16 result=-1;
if (LWGPIO_VALUE_HIGH == lwgpio_get_value(&btn1))
DEBUG_OUT("Button IDLE");
result = 1;
else
DEBUG_OUT("Button PRESSED");
result = 0;
Hope this helps
