Processor Expert disable ?
934件の閲覧回数
stockfrançois
  I have a question about using Processor Expert and MQX_Lite. When I make changes in the processor expert through the component inspector, NO CHANGES will be reported in the code or the architecture of the system.
In the component inspector, It is also writen "Processor Expert disable". What could I do to improve the saving in the PE modifications I have done.
Thanks in advance, have a nice day
Sincerly yours
FRS
PS: I have also posted  the same request in french, if some french-writing people answer, you're welcome
613件の閲覧回数
DavidS
Hi FRS,
Are you using standalone PE or PE in CW10.4/3/2?
Have you done "Help->Install New Software" to ensure tools are updated?
Is your component enabled? Right click on component and ensure check next to "Component Enabled".
Have you tried to create a new MQXLite project?
Which device are you using?
David
2 返答(返信)
613件の閲覧回数
stockfrançois
Thanks for quick answering. You're right. I have forgotten to enable the right component in the project explorer panel.
For information, I use a Kinetis MK10DN512ZVLL10 target with a homemade board.
Thanks for all,
Sincerly yours
bye
614件の閲覧回数
DavidS
Hi FRS,
David
