OPT_KEEPALIVE Broken in RTCS 4.2? Causing idle connection to RST in RTSC 4.2, but not 4.1
1,469件の閲覧回数
pmt
Contributor V
Greetings!
When I recently updated to RTCS 4.2.0.0 (and RTCS 4.2.0.1).  I have the OPT_KEEPALIVE property enabled on one of my "control" sockets that I am using for a home brew FTP server.
In RTCS 4.1, no issues, seems to work as intended.
In RTCS 4.2, when the control socket connection sits idle for a few minutes the server side (MQX/RTCS) the first KEEPALIVE sent ends up resetting the socket connection.  KEEPALIVE should not do this unless the remote side is gone.   Two keep alive probes from RTCS (ID=80 and 81), one keepalive response from the host , then RTCS resets the connection.
Any clues?!?!
PMT
6 返答(返信)
961件の閲覧回数
Carlos_Musich
HI PMT,
Workaround could be to call the setsockopt() after listen()/connect() returns.
Carlos
961件の閲覧回数
Carlos_Musich
Hi PMT,
I am nt having issueas with OPT_KEEPALIVE.
Can you please describe how can I reproduce this behavior?
Carlos
961件の閲覧回数
pmt
Contributor V
This is basically what I am doing:
Create a listening socket on the RTCS side with the following socket options:
     OPT_KEEPALIVE = 2
      OPT_TIMEWAIT_TIMEOUT = 5000
Connect to the socket (i.e. TELNET from PC).
Let the connection sit idle for the KEEPALIVE period, 2 minutes.
Connection will then reset as a result of the KEEPALIVE message.
Let me know if you can't reproduce, then I can work on creating a code snippet test case.
PMT
961件の閲覧回数
Carlos_Musich
Hi PMT,
it would be useful if you could share the code snippet.
Thanks!
Carlos
961件の閲覧回数
pmt
Contributor V
Carlos,
Test case at bottom.
Instructions:
Call ListenTask() with a port number of your choice, example ListenTask(23);
telnet to the port from a PC, "telnet x.x.x.x"
Don't any any activity on the socket... simply wait a couple minutes
The application has a keepalive of 1 minute.  It will incorrectly disconnect after this time.  Change the keepalive to 0 by changing FTPD_SOCKET_KEEPALIVE_TIMEOUT_M (0)
Try the same as above.  Socket will not disconnect.
This only happens in RTCS4.2, but not 4.1.
#include <mqx.h>
#include <bsp.h>
#include <rtcs.h>
#define FTPD_SOCKET_WAIT_TIMEOUT_MS (5000)
#define FTPD_SOCKET_KEEPALIVE_TIMEOUT_M (1)
#define FTPD_MAX_MESSAGE_SIZE (128)
#define FTPD_SESSION_LIMIT (6)
#define FTPD_PENDING_LIMIT (3)
static const uint32_t OptValueTimeWaitTimeout  = FTPD_SOCKET_WAIT_TIMEOUT_MS;
static const uint32_t OptValueKeepAliveTimeout = FTPD_SOCKET_KEEPALIVE_TIMEOUT_M;
// Session information
typedef struct
  bool    Active;
  uint32_t            CtrlSocket; // Socket handle for control connection
FTPD_SESSION;
static _task_id TaskCreate(void (_CODE_PTR_ TaskPtr)(uint32_t),
  uint32_t StackSize,
  uint32_t Priority,
  const char *Name,
  uint32_t Parameter)
  TASK_TEMPLATE_STRUCT Task;
  memset((void *) &Task, 0, sizeof(Task));
  Task.TASK_ADDRESS   = TaskPtr;
  Task.TASK_STACKSIZE = StackSize;
  Task.TASK_PRIORITY   = Priority;
  Task.TASK_ATTRIBUTES = MQX_FLOATING_POINT_TASK;
  Task.TASK_NAME = (char *) Name;
  Task.CREATION_PARAMETER = Parameter;
  return _task_create(0,0,(uint32_t) &Task);
// Handle a new session
static void SessionTask(uint32_t Parameters)
  FTPD_SESSION *SessionPtr = (FTPD_SESSION *) Parameters;
  char cmd[FTPD_MAX_MESSAGE_SIZE];
  uint32_t count = FTPD_SOCKET_KEEPALIVE_TIMEOUT_M;
  RTCS_attachsock(SessionPtr->CtrlSocket);
  printf("Socket connected with KEEPALIVE = %u\r\n", count);
  while(1)
  // read from socket and throw away data
  count = recv(SessionPtr->CtrlSocket, cmd, 1, 0);
  if (count == RTCS_ERROR) break;
  printf("Socket shutting down\r\n");
  shutdown(SessionPtr->CtrlSocket, FLAG_CLOSE_TX);
  SessionPtr->Active = FALSE;
  _task_destroy(_task_get_id());
  return;
// Listen Socket
void ListenTask(uint32_t ListenPort)
  struct sockaddr_in remoteAddr, localAddr;
  FTPD_SESSION FtpdSession[FTPD_SESSION_LIMIT];
  uint16_t addrLen;
  uint32_t i, Socket, SocketNew, Priority;
  uint32_t MaxPending  = FTPD_PENDING_LIMIT;
  // Init FTPd session tracking
  for (i=0; i<FTPD_SESSION_LIMIT; i++) FtpdSession[i].Active = FALSE;
  // store the current task priority
  _task_get_priority(_task_get_id(), &Priority);
  // create TCP/IP socket
  if ( (Socket = socket(AF_INET, SOCK_STREAM, 0)) == RTCS_HANDLE_ERROR)
  return;
    setsockopt(Socket, SOL_TCP, OPT_KEEPALIVE,        (void *) &OptValueKeepAliveTimeout, sizeof(OptValueKeepAliveTimeout));
  setsockopt(Socket, SOL_TCP, OPT_TIMEWAIT_TIMEOUT, (void *) &OptValueTimeWaitTimeout,  sizeof(OptValueTimeWaitTimeout));
  // Bind socket to the listen port
    localAddr.sin_family      = AF_INET;
    localAddr.sin_port        = ListenPort;
    localAddr.sin_addr.s_addr = INADDR_ANY;
  if (bind(Socket, (struct sockaddr_in *) &localAddr, sizeof(localAddr)) != RTCS_OK)
  shutdown(Socket, FLAG_CLOSE_TX);
  return;
  // Listen on listen port
  if (listen(Socket, MaxPending) != RTCS_OK)
  return;
    while(1)
  // Accept new sessions
  addrLen = sizeof(remoteAddr);
  SocketNew = accept(Socket, (struct sockaddr_in *) &remoteAddr, &addrLen);
  if (SocketNew == RTCS_HANDLE_ERROR)
  _time_delay(1000);
  else
  setsockopt(SocketNew, SOL_TCP, OPT_TIMEWAIT_TIMEOUT, (void *) &OptValueTimeWaitTimeout, sizeof(OptValueTimeWaitTimeout));
  // find a session and start the session task
  if (FtpdSession[i].Active == FALSE)
  // start a new session
  memset(&(FtpdSession[i]), 0, sizeof(FtpdSession[0]));
  FtpdSession[i].Active = TRUE;
  FtpdSession[i].CtrlSocket = SocketNew;
  RTCS_detachsock(SocketNew);
  // Spawn session handler
  if (TaskCreate(SessionTask, 1024, Priority, "Session", (uint32_t) &FtpdSession[i]) == MQX_NULL_TASK_ID)
  shutdown(SocketNew, FLAG_CLOSE_TX);
  break;
  // If no free session so close the connection
  if (i == FTPD_SESSION_LIMIT)
  // Limit the number of accept loops we process every second.
  _time_delay(250);
961件の閲覧回数
Carlos_Musich
HI PMT,
thank you, I reproduced this issue and confirmed this is a bug. I reported it to MQX development team. Just for your reference the report number is MQX-5684.
I will keep you informed about the status of the issue.
We really appreciate this inputs.
Carlos
