MQX 4.1 HTTP Server question
990 次查看
igor-imx
Hi Everyone
I just downloaded and got MQX 4.1 up and running with our new board, however i have noticed something strange.
Before this, we used MQX 4.0 with the older HTTP server implementation, however mqx 4.0 had a function "httpd_get_varval" which allowed me to extract the key/value pairs submitted through the http web form.
I can't seem to find this or an alternative function in the MQX 4.1. Am i missing something? how can i achieve the same functionality so i can port the rest of the code we have?
We are using this for device configuration through the web screens.
Any help will be highly appreciated. I also paste the example code of how the old function was used.
PRIVATE INT CGI_resetFault(HTTPD_SESSION_STRUCT *session)
  //Get the current configuration for this device
  UINT  uiLen                             = 0, i=0;
  CHAR  sClearFault[6][55]          = {0};
  CHAR                      * ucpBuffer   = NULL;
  INT     iError = SUCCESS;
  ucpBuffer = NG_MALLOC_ZERO(MAX_HTTP_BUFFER_SIZE);
  if(!ucpBuffer){iError = HTML_ERROR_INTERNAL; LRETURN;}
  if(!session->request.content_len) {iError = HTML_ERROR_MISSING_OR_INVALID_PARAMS; LRETURN;}
  uiLen = session->request.content_len;
  uiLen = httpd_read(session, ucpBuffer, (INT)((uiLen > MAX_HTTP_BUFFER_SIZE) ? MAX_HTTP_BUFFER_SIZE : uiLen));
  ucpBuffer[uiLen] = 0;
  session->request.content_len -= uiLen;
  if (
        httpd_get_varval(session, ucpBuffer, "Rf_d1", sClearFault[0], sizeof(sClearFault[0])) ||
        httpd_get_varval(session, ucpBuffer, "Rf_d2", sClearFault[1], sizeof(sClearFault[1])) ||
        httpd_get_varval(session, ucpBuffer, "Rf_d3", sClearFault[2], sizeof(sClearFault[2])) ||
        httpd_get_varval(session, ucpBuffer, "Rf_d4", sClearFault[3], sizeof(sClearFault[3])) ||
        httpd_get_varval(session, ucpBuffer, "Rf_d5", sClearFault[4], sizeof(sClearFault[4])) ||
        httpd_get_varval(session, ucpBuffer, "Rf_d6", sClearFault[5], sizeof(sClearFault[5]))
    iError = HTML_ERROR_MISSING_OR_INVALID_PARAMS; LRETURN; //Missing or invalid params
  for(i=0;i<6;i++)
    if(atol(sClearFault[i]))
      gsaDevs[i].ucToFaultCnt = 0;
  END;
  CGI_sendHttpResultMessage(session,SUCCESS, DEVICE_STATUS_PAGE_PATH);
  iError = session->request.content_len;
  return iError;
Thank you
417 次查看
igor-imx
I found the answer to the question
In the hval_web demo this function is provided, it just was excluded from the BSP in the new web server implementation
thank you
418 次查看
igor-imx
thank you
