MFS Cache Bug
MFS Cache Bug
952 次查看
leifzars
Provide MFS_sector_cache_invalidate with args first_sector = X and sectors = 1. Insure cache includes sector X.
The cache_record will not be invalidated!
Check the current code out...
last_sector = first_sector + sectors - 1; // so last_sector now equals X
if ((cache_record->SECTOR_NUM >= first_sector) && (cache_record->SECTOR_NUM < last_sector))
   //Do invalidation
The above evaluates to false, but the intent was for it to be true. Changing the second condition from < to <= fixes the issue.
标记 (2)
6 回复数
579 次查看
danielchen
Hi Leif:
Minimum number of sectors which MFS is able to keep in cache at a time is 2 sectors. There is a macro in mfs_cnfg.h.
#define MFSCFG_SECTOR_CACHE_SIZE 2
You also can refer to the section 2.5 in MQX_MFS_User_Guide.pdf for more details.
I will forward your solution to the develop team.  Thanks for your feedback.
579 次查看
leifzars
Daniel,
I am not sure that the sector cache size has anything to do with the invalidate function failing to invalidate a cached sector? A cached record is comprised of one sector, no matter the number of records (MFSCFG_SECTOR_CACHE_SIZE ).
MFSCFG_SECTOR_CACHE_SIZE defines the number of cache records, one sector per record.
The MFS_sector_cache_invalidate function allows you to request 1 or a region of sectors to be invalidated. In the case of trying to invalidate 1, it fails.
Thanks Leif
579 次查看
leifzars
Daniel,
What do you think?
579 次查看
danielchen
Hi Leif:
Yes , you are right.   from function MFS_sector_cache_invalidate_record we can see  it is one sector per record. This is an issue we need to fix.
579 次查看
leifzars
Good deal, thanks
579 次查看
leifzars
Found same issue in MFS_sector_cache_flush.
