Solved! Go to Solution.
SRR and IDE bits are separated in control register.
ID register bits 28-18 are to be set with standard ID bits 10-0 (most significant is highest).
ID register bits 28-0 are to be set with extended ID bits 28-0 (most significant is highest).
Parameter identifier of the function FLEXCAN_Tx_message() should always contain the ID bits in its lowest bits (starting from bit 0).
The best source is the source code and header files for FlexCAN peripheral.
PetrM
PetrM
