How to get to know the task status of MQX
1,332件の閲覧回数
george
Senior Contributor II
Hi all,
I want to have a function for fail safe in MQX using Kinetis.
I think that it becomes possible by detecting the task which is keeping being blocked by another task.
For example, those status is in mqx_priv.h.
390 /*--------------------------------------------------------------------------*/
391 /*
392 **                             TASK STATES
393 **
394 ** The following define all of the states that a task have.
395 */
396
397 /* All blocked states have this bit set */
398 #define IS_BLOCKED                      (0x001)
399
400 /* Some states may also have the task on a timeout queue when blocked */
401 #define IS_ON_TIMEOUT_Q                 (0x100)
402
403 /* Some states may also have their task descriptors on a queue when blocked */
404 #define TD_IS_ON_QUEUE                  (0x200)
405
406 /*
407 ** Some states may also have their task descriptors on a queue using their
408 ** AUX pointer fields in the TD
409 */
410 #define TD_IS_ON_AUX_QUEUE              (0x400)
411
412 /* Mask to remove queueing and timeout bits */
413 #define STATE_MASK                      (0x0ff)
414
415 #define READY                           (0x02)
416 #define BLOCKED                         (0x02 | IS_BLOCKED)
417 #define RCV_SPECIFIC_BLOCKED            (0x04 | IS_BLOCKED)
418 #define RCV_ANY_BLOCKED                 (0x06 | IS_BLOCKED)
419 #define DYING                           (0x08 | IS_BLOCKED)
420 #define UNHANDLED_INT_BLOCKED           (0x0A | IS_BLOCKED)
421 #define SEND_BLOCKED                    (0x0C | IS_BLOCKED)
422 #define BREAKPOINT_BLOCKED              (0x0E | IS_BLOCKED)
423 #define IO_BLOCKED                      (0x10 | IS_BLOCKED | TD_IS_ON_QUEUE)
424
425 #define SEM_BLOCKED                     (0x20 | IS_BLOCKED)
426 #define MUTEX_BLOCKED                   (0x22 | IS_BLOCKED | TD_IS_ON_QUEUE)
427 #define EVENT_BLOCKED                   (0x24 | IS_BLOCKED)
428 #define TASK_QUEUE_BLOCKED              (0x28 | IS_BLOCKED | TD_IS_ON_QUEUE)
429 #define BLOCKED_ON_AUX_QUEUE            (TD_IS_ON_AUX_QUEUE|IS_BLOCKED)
430 #define LWSEM_BLOCKED                   (0x2A | BLOCKED_ON_AUX_QUEUE)
431 #define LWEVENT_BLOCKED                 (0x2C | BLOCKED_ON_AUX_QUEUE)
Please tell me how to get to know each task status from other task.
And, if there is a way good for others, please let me know.
George
タグ(4)
482件の閲覧回数
c0170
Senior Contributor III
Hello Goerge Fukutomi,
I remember there was one similar request, Task Manager in MQX. Please follow this link, might partially answer your question:
https://community.freescale.com/thread/302553
MartinK
483件の閲覧回数
c0170
MartinK
