DNS issue
DNS issue
824 次查看
aryavijayan
We have observed that the DNS server is failing to resolve the IP address. This is mostly seen when we switch the router OFF/ON. But that time we can ping the DNS IP successfully. Note that other devices are working in the same network without issues. Please provide a solution.
Another question is should we start DNS client when we retrieve IP from DHCP server? We are using the below calls to get IP from DHCP server.
ipcfg_bind_dhcp_wait(),
dnsIPAddress = ipcfg_get_dns_ip(ENET_DEVICE,0)
Should I call ipcfg_add_dns_ip(ENET_DEVICE, dnsIPAddress ) after ipcfg_get_dns_ip()??
More details:
OS                     : MQX 4.0.2
Platform            : K60
Arya
4 回复数
595 次查看
danielchen
Hi Arya:
I would suggest you refer to MQX 4.2.0  and patched 4.2.0.2. In this version, we fixed one DNS bug, it seems related your issue.
Note: If this post answers your question, please click the Correct Answer button or helpful. Thank you!
595 次查看
aryavijayan
Hi Daniel,
Thank you for the response.
Well, from where can I download patched version 4.2.0.2?  I couldn't find it in MQX™ Classic Software Solutions|NXP. Could you please share the link?
Thanks & Regards,
Arya
595 次查看
danielchen
Hi arya vijayan
Please try this link
MQX™ Software Solutions - Releases and Patches|NXP
Have a nice day,
595 次查看
aryavijayan
Hi Daniel,
Thank you so much!!
Arya
