CodeWarrior 10.x & MQX Documentation?
BenG
I normally use IAR Embedded Workbench, but I want to experiment with using Code Warrior. I'm not overly familiar with the Eclipse IDE/Interface but I can do some basic development with it.
Is there any documentation available which covers using MQX 3.x with CodeWarrior 10.x?
I can find documentation for  MQX 3.8 and CW 10.x, but no documentation that covers both together. The MQX documentation that refers to CodeWarrior refers to the "classic" version (i.e. 6.x/7.x) (e.g. AN3905) which is obviously significantly different from the Eclipse interface used in 10.x,
LuisCasado
Have you seen this doc? It is part of MQX3.7 docs
LuisCasado
BenG
Cheers Luis,
That's exactly what I was after.
