- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
Hello Expert
I want to initialize SRAM which has ECC error using e_stw. Because I want to clear a few bytes of Ram memory.
But there was a Exception when I used e_stw.
sram_init_some:
e_lis r5, SOME_RAM_SIZE@h # Initialize r5 to size of SRAM (Bytes)
e_or2i r5, SOME_RAM_SIZE@l
# e_srwi r5, r5, 0x6
mtctr r5
# Set Base Address of the internal SRAM
e_lis r5, SOME_RAM_START@h
e_or2i r5, SOME_RAM_START@l
sram_init_some_loop:
e_stw r16,0(r5)
e_addi r5,r5,4
e_bdnz sram_init_some_loop
Can't I use e_stw to init SRAM?
I can't, how to initialize a few bytes of SRAM ? (not 64 bytes using e_stmw)
Thank you
Jaejyn
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I resolved it.
I used e_stmw and r30/r31 register.
I set the resolution of clearing size as 8 bytes.
Thank you anyway.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
As there is ECC protection on SRAM the operation executed is read-modify-write.
So you have to use stmw.
Peter
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I resolved it.
Thank you anyway.
