Dear All,
I use MPC5777C.
I want to be informed via interrupt if lockstep mode is disable.
If It is possible, How can I implement it?
Please give me advice.
Thank you
SIU_LOCKSTEP register indicated whether lockstep is enabled or disabled, but it does not trigger anything. It may be only indicative for user to check for instance whether his DCF programming has been done correctly or not.
However there is a fault for these event, if FCCU configures properly, it may indicate ALARM interrupt. But its intention is rather to indicate it has been disabled when it is supposed to run.
