another question on spi slave mode
626 次查看
lyk
Hello:
         I have another question on spi slave mode:
         if I use DSPI2 in slave mode, A3 as the chip select pin, how to config it?
         should I not only config the MSCR[3] SSS value equal 0010,but also config IMCR[49] SSS value equal 0001?
         Thank you!
570 次查看
PetrS
to use A3 pin as slave's chip select input you need to set
SIUL2.MSCR[3].R = 0x000C0000;            // Pad PA3: Enable input buffer and input hysteresis
SIUL2.IMCR[49].R = 0x1;            // Pad PA3: is SPI_2 CS0
BR, Petr
