Hello everyone;
I will send commands from RAM to eQADC FIFOs with eDMA. As far as I know, I have to set eDMA priority higher than other master ports for SRAM on XBAR. For this purpose, I did settings below.
XBAR->PORT[2].CRS = 0x00100004;
XBAR->PORT[2].PRS = 0x76504321;
XBAR->PORT[4].PRS = 0x76504321;
XBAR->PORT[4].CRS = 0x00100004;
These are correct and enough to set eDMA for the highest priority?
Solved! Go to Solution.
Hi, you should also set it for AIPS_1 and AIPS_0.
