Why CMU_1 Report FLL Event
1,063 次查看
zhouxx
Hi:
      I Use CMU_1 to monit the CHKR_CLK;
      System clok Divider 0 is  1, so  CHKR_CLK is 100MHz;
      I set CMU_1 HFREF 440  LFREF 360, why the CMU_1 report FLL event?
      Help me Plz。
6 回复数
891 次查看
lukaszadrapa
solution is to enable lockstep core. LOCKSTEP EN in DCF in UTEST is 1 by default, so this is OK. It just need to be enabled also in boot header:
Then it will work as expected.
Lukas
891 次查看
zhouxx
Hi:
   I Try to solve the issues by write MC_ME_CCTL2 register,it's working fine。why?
891 次查看
lukaszadrapa
yes, lock step core will increase the current consumption. The lock step core should be enabled via RCHW, enabling via CCTL2 is not expected use case.
Lukas
891 次查看
zhouxx
tks for your reply。
According what you said,I solved the issues. Enable the lockstep core will increase the system load?
891 次查看
zhouxx
MPC5746R
891 次查看
zhouxx
Because CHKR_CLK Is not Enable? How to Eanle the CHKR_CLK
