Reg Ethernet configuration and example for FEC MII or RMII
vignesh_v
   I need to perform ethernet periphereal test validation. Iwent through the example code for mpc5777m can the similar configuration be used and can some one walkthrough how it works as im quite new to FEC.
vignesh_v
Thx ;il foolow the same. one more help /query.
1. How to use a MDO pin as a digital pin to read and write
2. how to use EMIOS for the same and additionally how can it be used to set frequency output say 5HZ
petervlna
I have FEC example code for MPC5777M with is demonstrating and describing usage of FEC.
However this code is not my own, so I would rather share it via official service request than via community.
Please submit request and I will sent it to you:
Support | NXP
regards,
Peter
vignesh_v
Could u pl guide me how  to submit a Request
petervlna
Sure, there is a guide on community:
https://community.nxp.com/docs/DOC-329745
Peter
