MPC5775E SDADC sample not correct
yangyulong
My init code :
void sdADC_Init()
sdadc_init(Mcal_SDADC_OSR_24, Mcal_SDADC_Gain_2, Mcal_SDADC_FTHLD_8, Mcal_SDADC_DIFF);
void sdadc_init(uint8_t pdr, uint8_t gain, uint8_t fifo_thld, uint8_t inp_mode)
* SD ADC 1 CONFIGURATION
SDADC_1.SFR.R = 0x1B; // clear all the status flags
SDADC_1.FCR.B.FRST = 1; // generate reset to flush FIFO
SDADC_1.FCR.B.FTHLD = fifo_thld; // FIFO threshold - overcome generates FIFO full event flag
SDADC_1.FCR.B.FSIZE = 3; // FIFO size: 0 - 1 word, 1 - 4 words, 2 - 8 words, 3 - 16 words
SDADC_1.FCR.B.FOWEN = 0; // disable FIFO overwrite
SDADC_1.FCR.B.FE = 1; // enable FIFO
SDADC_1.RSER.B.DFFDIRS = 1; // DMA request on data FIFO full
SDADC_1.RSER.B.DFFDIRE = 1; // data FIFO full request enable
SDADC_1.MCR.B.MODE = inp_mode; // input mode: 0 - differential, 1 - single-ended
SDADC_1.MCR.B.PDR = pdr; // Oversampling rate
SDADC_1.MCR.B.PGAN = gain; // Gain
SDADC_1.MCR.B.HPFEN = 1; // High-pass filter enabled
SDADC_1.MCR.B.EN = 1; // internal SDADC modulator enabled
SDADC_1.OSDR.B.OSD = 1; // set the output settling delay
SDADC_1.CSR.B.ANCHSEL = 0; // analog input channel AN[x] selection
SDADC_1.MCR.B.TRIGEN = 1; // enable HW trigger
* SD ADC 2 CONFIGURATION
SDADC_2.SFR.R = 0x1B; // clear all the status flags
SDADC_2.FCR.B.FRST = 1; // generate reset to flush FIFO
SDADC_2.FCR.B.FTHLD = fifo_thld; // FIFO threshold - overcome generates FIFO full event flag
SDADC_2.FCR.B.FSIZE = 3; // FIFO size: 0 - 1 word, 1 - 4 words, 2 - 8 words, 3 - 16 words
SDADC_2.FCR.B.FOWEN = 0; // disable FIFO overwrite
SDADC_2.FCR.B.FE = 1; // enable FIFO
// DMA settings
SDADC_2.RSER.B.DFFDIRS = 1; // DMA request on data FIFO full
SDADC_2.RSER.B.DFFDIRE = 1; // data FIFO full request enable
SDADC_2.MCR.B.MODE = inp_mode; // input mode: 0 - differential, 1 - single-ended
SDADC_2.MCR.B.PDR = pdr; // Oversampling rate
SDADC_2.MCR.B.PGAN = gain; // Gain
SDADC_2.MCR.B.HPFEN = 1; // High-pass filter enabled
SDADC_2.MCR.B.EN = 1; // internal SDADC modulator enabled
SDADC_2.OSDR.B.OSD = 1; // set the output settling delay
SDADC_2.CSR.B.ANCHSEL = 0; // analogue input channel AN[x] selection
SDADC_2.MCR.B.TRIGSEL = 0; // SDADC_1 trigger output selected as an input trigger for SDADC
SDADC_2.MCR.B.TRIGEDSEL = 1; // rising edge of trigger input selected
SDADC_2.MCR.B.TRIGEN = 1; // enable HW trigger
void sdadc_start(void)
// start the SDADC_1 by SW trigger
SDADC_1.STKR.R = 0xFFFF;
uint32 sdadc1[16];
uint32 sdadc2[16];
void edma_init(void)
uint8_t hsr_ch = 48; // this number TBD
// DMA B ch 36 - SDADC0 result ready
// DMA B ch 37 - SDADC1 result ready
// DMA channels for eQADC:
// DMA settings for SDADC_0 request
DMA_B.TCD[36].SADDR.R = (uint32_t)&SDADC_1.CDR.R;
DMA_B.TCD[36].ATTR.B.SMOD = 0; /* source address modulo*/
DMA_B.TCD[36].ATTR.B.SSIZE = 2; /* source data size: 32bit */
DMA_B.TCD[36].ATTR.B.DMOD = 0; /* destination address modulo: 32 datawords each 4 bytes */
DMA_B.TCD[36].ATTR.B.DSIZE = 2; /* destination data size: 32bit */
DMA_B.TCD[36].SOFF.R = 0; /* source address signed offset */
DMA_B.TCD[36].NBYTES.MLNO.R = 32; /* inner "minor" byte count */
DMA_B.TCD[36].SLAST.R = 0; /* TCD Last Source Address Adjustment */
DMA_B.TCD[36].DADDR.R = (vuint32_t)sdadc1; /* destination address */
DMA_B.TCD[36].CITER.ELINKYES.B.ELINK = 0; /* Enable channel-to-channel linking on minor-loop complete */
DMA_B.TCD[36].CITER.ELINKYES.B.LINKCH = hsr_ch; /* Minor Loop Link Channel Number */
DMA_B.TCD[36].CITER.ELINKYES.B.CITER = 4; /* current major iteration count */
DMA_B.TCD[36].DOFF.R = 4; /* signed destination address offset */
DMA_B.TCD[36].DLASTSGA.R = -128; /* last destination address adjustment /scatter gather address */
DMA_B.TCD[36].BITER.ELINKYES.B.ELINK = 0; /* enable channel-to-channel linking on minor loop complete */
DMA_B.TCD[36].BITER.ELINKYES.B.LINKCH = hsr_ch; /* Minor Loop Link Channel Number */
DMA_B.TCD[36].BITER.ELINKYES.B.BITER = 4; /* beginning major iteration count */
DMA_B.TCD[36].CSR.B.MAJORELINK = 1; /* enable channel-to-channel linking on major loop complete */
DMA_B.TCD[36].CSR.B.MAJORLINKCH = hsr_ch; /* Major Loop Link Channel Number */
// DMA settings for SDADC_1 request
DMA_B.TCD[37].SADDR.R = (uint32_t)&SDADC_2.CDR.R;
DMA_B.TCD[37].ATTR.B.SMOD = 0; /* source address modulo*/
DMA_B.TCD[37].ATTR.B.SSIZE = 2; /* source data size: 32bit */
DMA_B.TCD[37].ATTR.B.DMOD = 0; /* destination address modulo: 32 datawords each 4 bytes */
DMA_B.TCD[37].ATTR.B.DSIZE = 2; /* destination data size: 32bit */
DMA_B.TCD[37].SOFF.R = 0; /* source address signed offset */
DMA_B.TCD[37].NBYTES.MLNO.R = 32; /* inner "minor" byte count */
DMA_B.TCD[37].SLAST.R = 0; /* TCD Last Source Address Adjustment */
DMA_B.TCD[37].DADDR.R = (vuint32_t)sdadc2; /* destination address */
DMA_B.TCD[37].CITER.ELINKNO.B.ELINK = 0; /* Disable channel-to-channel linking on minor-loop complete */
DMA_B.TCD[37].CITER.ELINKNO.B.CITER = 4; /* current major iteration count */
DMA_B.TCD[37].DOFF.R = 4; /* signed destination address offset */
DMA_B.TCD[37].DLASTSGA.R = -128; /* last destination address adjustment /scatter gather address */
DMA_B.TCD[37].BITER.ELINKNO.B.ELINK = 0; /* Disable channel-to-channel linking on minor loop complete */
DMA_B.TCD[37].BITER.ELINKNO.B.BITER = 4; /* Beginning major iteration count */
DMA_B.TCD[37].CSR.B.MAJORELINK = 0; /* Disable channel-to-channel linking on major loop complete */
void edma_start(void)
/* Enable eDMA channels*/
DMA_B.SERQ.R = 36; /* SDADC0 result ready */
DMA_B.SERQ.R = 37; /* SDADC1 result ready */
The SDADC_AN[0] connent to 1.25V voltage, the SDADC_AN[1] connect to GND. and the sdadc read back value:
I have change the SDADC_AN[0] to other voltages, but the adc read value was not effect .
davidtosenovjan
firstly I would ask whether you have ever SDADC running for instance with simple configuration used in my example here:
Example MPC5777C-SDADC_simple GHS614
I have certain doubts about SDADC configuration, I am missing send key to reset ADC to start sampling, also I guess OSDR would require different values. Is your code based on certain example code?
yangyulong
My code is based solely on register descriptions in the technical manual and has not run any other test Demo.
