MPC5748g Flexray clock
搜索替代
593 次查看
WM
MPC5748g Flexray clock using PLL how to set
标记 (1)
559 次查看
davidtosenovjan
Yes, it is the configuration
583 次查看
davidtosenovjan
You may have two options:
- either 40MHz directly feeded by crystal oscillator
- or 80MHz clock feeded from PLL
I am recommending to use following clock configurator:
https://www.nxp.com/docs/en/application-note/AN5392.pdf
566 次查看
WM
Hello, davidtosenovjan
    Thank you for your answer.
     If FR_MCR[CLKSEL] is 1 in MPC5748, check whether other configurations are required in flexray PE clock?  I have configured FS80=80MHz.
560 次查看
davidtosenovjan
