MPC5748G-UART receiver is not working
kalai
HI,
    i run example code linflexd_uart_echo_mpc5748g and uart_pal_mpc5748g both are transmit the data  but receiver is not working
thanks
kalai
PetrS
I tested both examples and it works, I can receive bytes sent from PC.
Just for uart_pal_mpc5748g example, PC terminal must be set to send endline upon enter as mentioned in example doxygen file.
For linflexd_uart_echo_mpc5748g example I just increase timeout value in ReceiveData Blocking function so I was able to write Hello from terminal in time.
BR, Petr
