did you follow these instructions in the user manual?
And this is from the release notes:
This is the most common reason. The application will not work if the steps above are not implemented.
Lukas
it's not about the settings of Rappid tool or about the RBF file. It's about the application which you are going to download by the bootloader. You need to implement the steps mentioned above.
Lukas
Problem has been solved,Thank you
