Hello everyone, I recently purchased a DEVKIT-MPC5744P to implement BMS design. The power management chip used is MC33771, and the development environment is S32D. I would like to ask you what you need to pay attention to. It would be better if there are examples~
#MPC5744
Solved! Go to Solution.
The kit is plug and play if you use the default SW. Like examples from NXP present in S32design studio.
I see no risks here except censorship (but I guess you will skip it in development).
You can basically load any SW into it.
Here is the guide for uC and SBC connection:
https://www.nxp.com/docs/en/application-note/AN5099.pdf
on top of that you can go trough getting started guide:
https://www.nxp.com/document/guide/getting-started-with-the-devkit-mpc5744p:NGS-DEVKIT-MPC5744P
All information available for this kit and all supporting documentation can be found at:
best regards,
Peter
best regards,
Peter
Yes, there are SPI examples in the S32DS in RTD packages for MPC5744P.
Install S32DS, driver package and open project from example.
Peter
In S32DS you have plenty of examples for evaluation:
Just install driver package you want to use and create project from example.
Or you can use our examples posted on community:
https://community.nxp.com/t5/MPC5xxx-Knowledge-Base/MPC5-software-example-list/ta-p/1102445#MPC5744P
Peter
