MPC5643L Test flash memory
搜索替代
448 次查看
Pat
Do you have an example or real values for the fields PART ID 1 H/L and PART ID2  of the Test flash memory of MPC5643L  ?
RM rev10 :
My Current Test flash memory values :
Pat
标记 (2)
346 次查看
davidtosenovjan
Hi, I would guess it is only related to KGD (Known Good Die). As all KGD references has been removed, apparently it is not a option and these field don't need to be programmed in the factory.
346 次查看
Pat
Hi davidtosenovjan‌,
So, these fields should be also removed from the last MPC5643LRM  Rev10, Table 23-24. Test flash information.
Thank you.
BR,
Pat
