MPC5606B startertrak board max input voltage for port pins
1,755件の閲覧回数
sundar19
I am using mpc5606b startertrak dev board . I have attached external transceivers TJA1050 with the CAN bus pins. I have supplied 5V to transceivers and thus the same logic voltage is applied to CAN port pins of mpc5606b. Can mpc5606b pins take 5V input? Will it damage the pins?
1,740件の閲覧回数
lukaszadrapa
TRK-MPC5606B is supplied by 5V only, it's not configurable to 3.3V. So, there's no problem, you can connect a transceiver supplied by 5V.
The microcontroller itself supports both 3.3V and 5V supply voltage.But if 3.3V is used, the GPIO pins are not 5V tolerant.
Lukas
5 返答(返信)
1,741件の閲覧回数
lukaszadrapa
Lukas
1,733件の閲覧回数
sundar19
You saying that if I power up mpc5606b with 3.3V , then its pins arent 5V tolerant?
thank you
1,727件の閲覧回数
lukaszadrapa
Yes, you can find in the datasheet:
Lukas
1,728件の閲覧回数
sundar19
Thank you
1,736件の閲覧回数
sundar19
Thank you so much
