MPC5566 EVB is in continuous fault and reset mode
次の代わりに検索
631件の閲覧回数
harshal_pawar
I have two MPC5566 EVBs. On one board code is uploading (using PE micro USB Multilink & CW 5.9.0) & its working fine but on second board the FAULT & RESET LEDs are continuously glowing.
And while uploading code on second board following error is repeating:
1.Debugger retrying force to background mode.
2. Can not enter background mode.
3 返答(返信)
466件の閲覧回数
lukaszadrapa
what were the last steps before this problem? Could you check the reset line by oscilloscope? Is it low all the time after power-on? Are there the same jumper settings on both boards? Have you measured supply voltages?
Lukas
466件の閲覧回数
harshal_pawar
The jumper setting on both boards is same & supply voltages are also proper.
The reset line waveform is continuously high (3.9V) after power-on unless RESET switch is pressed.
I have also observed that on working board only LED_SPEED is continuously glowing while on faulty board LED_LINK, LED_SPEED & LED_ACT all are continuously glowing.
466件の閲覧回数
lukaszadrapa
can you see 3.9V on reset on both boards? Did you check that by oscilloscope or did you just measured the voltage?
Lukas
