Illegal exception while accessing pcr/gpdo in user mode(MPC5777C)
Indra
 I used this code
//User mode
__asm__(" mfmsr %r23 ");
__asm__(" e_add16i %r24, %r23, 0x4000 ");
__asm__(" mtmsr %r24 ");
//gpdo toggling
vint32_t time = 0;
SIU.PCR[LEDPIN].R= 0x0200;
while(1){
while(time < 1000000)
SIU.GPDO[LEDPIN].R ^= 1;
time++;
time = 0;
This is for gpdo toggling simple application but I am getting illegal instruction exception in ESR and bits MAV,ST,G,BUS_WRERR in MCSR are set I dont know why this happening
what should I do?
M.V.S.I
lukaszadrapa
OK, there's no problem with MMU, all TLB entries are "user access allowed".
After deeper investigation, I found that it's caused by default configuration of Peripheral Bridge.
It's necessary to configure AIPS_1_OPACRA to 0x44440444 (default value is 0x44444444):
After this configuration, it works as expected.
Lukas
lukaszadrapa
Hi @Indra
could you show me your MMU configuration? If this happens after enabling of user mode then it points directly to MMU, most likely.
Lukas
Indra
Hi @lukaszadrapa
I've attached my mmu config please have a look at it
lukaszadrapa
Lukas
Indra
Thank you @lukaszadrapa  it works.
