AN2849 pwm_example2 file
William_Klaus
In the application note AN2849 a code example named pwm_example2.c is cited, but I couldn't find any file. Where can I access this example?
lukaszadrapa
Hi @William_Klaus
this is quite outdated but I found AN2849SW.zip which is associated with this application note - attached. It seems it's not available on the web anymore.
It contains readme file which describes which other application notes and associated SW packages are needed.
Lukas
lukaszadrapa
Hi @William_Klaus
Lukas
