Example MPC5744P FlexPWM CTU ADC synchronization GHS614
* Detailed Description:
* This example shows synchronization between FlexPWM, CTU and ADC modules.
* The FlexPWM Submodule 0 is initialized to generate PWM signal, and rising edge
* of PWM B0 signal is used to generate trigger signal for CTU module. The CTU module
* sends two commands to ADCs. Single conversion mode is used, so ADC0 ch0 and ch1
* are sampled. The conversion result is used to modify PWM B0 rising egde position
* and change delay between external trigger and ADC sequence triggering.
* Test HW:  MPC57xx
* Maskset:  1N65H
* Target :  internal_FLASH
* Fsys:     200 MHz PLL with 40 MHz crystal reference
* EVB connection:
* P8.1  - A[0]  .. GPIO output, used to see CTU-ADC ISR period
* P9.1     - B[7]  .. ADC0 AN[0] input
* P9.2     - B[8]  .. ADC0 AN[1] input
* P16.4 - I[3] .. CTU0 EXT TRG output
* P8.12    - A[11] .. FlexPWM A[0] output
* P8.11    - A[10] .. FlexPWM B[0] output
* connect Trimmer J53.1 to P9.1 to change position of PWM B0 rising edge
* connect Trimmer J53.1 to P9.2 to change CTU trigger delay from PWM B0 rising edge
* see CTU0 EXT TRG output signal (toggle on each trigger) on P16.4 with respect of PWM signals
Comments
wsc
There are some errors in this file for "MPC5744P_IsrVecTab.c". But I don't know how to solve it ..
No ratings
Version history
Last update:
‎04-10-2015 05:06 AM
Updated by:
