N947 Dual Boot - knowing which image was booted
JohnKay
Once I boot from Image 1, is there an attribute that I can programmatically check to indicate that I booted from Image 1 and an update image should be written to Image 0?
Dual Boot and the Secure Provisioning Tool both work great!
marek-trmac
Hi John,
it should be possible to read image version stored in the image.
Marek
JohnKay
Got it. All I have to do is check the PC.
static __inline__ void * get_pc(void) {
void *pc;
asm("mov %0, pc" : "=r"(pc));
return pc;
JohnKay
Thanks for your reply.
The question is, in a dual boot configuration, how can i determine which image i booted from, 0 or 1.
If I booted from Image 0, then I know that I should load the new firmware into Image 1, or vise versa.
I could read and compare the versions in both Images, but if the validation failed on the new Image 0, then I would fallback to Image 1, but comparing the header data, I would think I booted from Image 0.
Not a show stopper, I'll find a workaround.
Thank you.
marek-trmac
Hi John,
Marek
