Confusing state diagram in AN14145 - Flash Memory Swap Features on MCX N Series
laodzu
Looking at AN14145 and Figure 2, I am somewhat confused about the error cases when the attempt to run the first "logical" image does not boot. I.e. the diagram gives this possible execution order:
Is there a second image file? Yes
Whether second image version is greater than first?  No
Start first image
Startup successful? No
Start second image
Startup successful?  Yes
Run first image
The last state should be "Run second image". The same problem exists on the symmetric case when the second image should be tested first and does not boot.
I know, it's kind of cosmetic, but its really confusing.  Would be good to fix this in the document.
Thanks in advance!
https://www.nxp.com/webapp/Download?colCode=AN14145
Labels (2)
Omar_Anguiano
Thank you for your feedback!
I will inform this suggestion to the corresponding team so it is considered.
Omar
laodzu
Hi Omar,
thanks for passing on my feedback to the right team.  I appreciate that!
Best wishes
 Detlev
Omar_Anguiano
Omar
