evkmimrt1060_csi_ccir656 rgb565
669 次查看
tomtalkington
I ran this driver demo with the supplied camera and LCD for my kit.  It works but the focus is set at about 2cm from the camera lens.  Is this normal behavior or do I have something setup wrong?  The datasheet for the MT9M114 claims autofocus.  New to cameras and video in general.  Any pointers would be appreciated.
Tom
标记 (4)
571 次查看
Hi Tom
in general such command (turn on autofocus) can be added to driver, however
from available datasheet sensor seems autofocus is not supported
https://www.onsemi.com/pub/Collateral/MT9M114-D.PDF
One can contact vendor support for additional details
Technical Support | ON Semiconductor
571 次查看
tomtalkington
Thanks Igor.  Looks like the problem was a simple mechanical adjustment of the lens on the camera.  Be careful as it is easy to scratch the lens.  Luckily I had two cameras.  Had to turn it clockwise a couple of turns using the demo app to see the image for fine tuning.
