I am currently aiming to write a second stage boot loader ultimately for the LPC55s28. I wish to implement firmware update as drag and drop to a USB mass storage device - similar to the way MBED devices work. I have external eMMC FLASH where I can hold the image prior to FLASHing
I was hoping to base this on the example given in the app note AN12327. I realise this is for the LPC55S69 but the parts are very similar so am hoping to port it as a starting point. However, I cannot find the code referred to in the SDK for either of these parts.
Please can someone tell me where I can find the example code referred to in the app note.
If this is not the right place to start then I would be grateful to be pointed in the right direction.
(I already have the mass storage part working. The parts I am missing are how to prepare images with the correct headers and how to program the FLASH - presumably whilst running from code copied to RAM)
Many thanks
解決済! 解決策の投稿を見る。
Please download AN12327SW from here
https://www.nxp.com.cn/docs/en/application-note-software/AN12327SW.zip
Jun Zhang
Jun Zhang
I am trying to implement a second stage bootloader to boot an image stored on an SD card which is connected over the SPI interface to the LPC55S16-EVK.
For this I am studying the document AN12327.
Under point 3.2.2 on page 9 it says open, compile and load the project lpc55xx_dsbl.
So I am working with the MCUXpresso IDE and I tried to import this project there. But I am not able to import it properly. Could you give me a hint how to import it in the MCUXpresso IDE or how to flash my LPC55S16-EVK board with this example project over the elftosb tool?
best regards,
Corsin Obrist
HI nxp-obrist
This thread was closed. please create a new thread for your question. NXP support team will help you.
Jun Zhang
Thank you so much.
