FreeRTOS_CLIRegisterCommand not working
1,201件の閲覧回数
jren68
 I am following this tutorial and have
1. Implemented a Command
static BaseType_t prvTaskStatsCommand( int8_t *pcWriteBuffer,
                                          size_t xWriteBufferLen,
                                          const int8_t *pcCommandString )
    ( void ) xWriteBufferLen;
    return pdFALSE;
2.  created the mapping
static const CLI_Command_Definition_t xDelCommand =
    "abc",
    "del <filename>: Deletes <filename> from the disk\r\n",
      prvTaskStatsCommand,
    1
3.  registered with FreeRTOS+CLI
void vRegisterCLICommands( void )
int a = FreeRTOS_CLIRegisterCommand( &xDelCommand );
printf("hello world %i\n", a);
I put vRegisterCLICommands() in main and the printout is "hello world 1", indicating the registration is successful.
Then I tried
help abc
in the debug console in MCUXpresso, but abc is not there. This is what I got
Undefined command: "abc".  Try "help".
why FreeRTOS_CLIRegisterCommand is not working?
what should I do after register the command with FreeRTOS_CLI?
3 返答(返信)
958件の閲覧回数
jren68
I figured out what's the problem...the console is the gdb console, not a shell or UART terminal that connects directly to the board...
958件の閲覧回数
danielchen
Thanks for sharing your idea.
958件の閲覧回数
jren68
most of the board SDK will have a shell demo, that script can be used as a console and one can call the registered functions from the shell successfully.
