FatFs with sdspi driver
Search instead for
yanlong_gao
    My board is LPC54114, I want to use the SPI interface and FatFs to read/write files to a SD card, the FatFs source code in the SDK seem not contain the sdspi driver? where can i find it?
Thanks.
Tags (5)
FelipeGarcia
Hello Will,
I recommend you to read the following documents in order to implement FatFs using SPI.
Porting FatFs file system to KL26 SPI SD card code
    https://www.nxp.com/docs/en/application-note/AN10406.pdf
Hope it helps!
Felipe
FelipeGarcia
Hello Will,
Hope it helps!
Felipe
