DMA GetRemainingBytes bug report
搜索替代
736 次查看
mstumbra
Hello
Bug in fsl_dma.c of LPC546xx SDK v2.2.0;
function uint32_t DMA_GetRemainingBytes(DMA_Type *base, uint32_t channel)
return statement doesn't perform masking and bit shifting as in other functions of same source file. Also "+1" performed for register value, instead of actual XFERCOUNT value.
fix:
return base->CHANNEL[channel].XFERCFG + 1;
change to
return ((base->CHANNEL[channel].XFERCFG & DMA_CHANNEL_XFERCFG_XFERCOUNT_MASK) >> DMA_CHANNEL_XFERCFG_XFERCOUNT_SHIFT) + 1;
标记 (3)
486 次查看
Carlos_Mendoza
Hi Michael,
Thank you for reporting this, I have sent this report to the SDK development team.
Best Regards!
Carlos Mendoza
Technical Support Engineer
