Bug in SPI_MasterTransferGetCount() fsl_spi.c from SDK_2.2_FRDM-KL25Z
508 次查看
Q_man
I'm using the SPI_MasterTransfereGetCount() function to detect when a none-blocking transfer is completed:
/* transfere a block of data */
SPI_MasterTransferNonBlocking(BCC_SPI_SPI_BASE, &spi_master_handle, &xfer);
/* Wait until transfer is finished. */
while ( (kStatus_NoTransferInProgress != SPI_MasterTransferGetCount(BCC_SPI_SPI_BASE, &spi_master_handle, &count)) && (timeout > 0U))
     timeout--;
Debugging the problem I found that the following line is incorrect:
status_t SPI_MasterTransferGetCount(SPI_Type *base, spi_master_handle_t *handle, size_t *count)
    assert(handle);
    status_t status = kStatus_Success;
//    if (handle->state != kStatus_SPI_Busy)    /* wrong */
    if (handle->state != kSPI_Busy)    /* correct */
        status = kStatus_NoTransferInProgress;
    else
    {        /* Return remaing bytes in different cases */
        if (handle->rxData)
            *count = handle->transferSize - handle->rxRemainingBytes;
        else
            *count = handle->transferSize - handle->txRemainingBytes;
    return status;
374 次查看
danielchen
Hi Wolfgang:
Thanks for your feedback and I will issue a internal ticket to software team.
