how to run gdb outside of the IDE?
次の代わりに検索
1,651件の閲覧回数
rob4
I am using MCUxpresso 11.1 with a stock MIMXRT1060-EVK board.
Can anybody provide guidance on how to manually start gdb outside the IDE and attach to the board?
I've found the gdb executable (/arm-none-eabi-gdb), but haven't had any success in connecting to the target. I would like to be able to load the executable image via MCUxpresso, then start up arm-none-eabi-gdb outside the IDE. I expect to tell gdb "target remote localhost:<port>" but nothing I've tried seems to work.
thanks!
5 返答(返信)
1,559件の閲覧回数
ErichStyger
Senior Contributor V
Not sure I understand the motivation behind this. But if you want to run gdb manually (commandline, scripting), you might have a look at Tutorial: MCUXpresso SDK with Linux, Part 2: Commandline Debugging with GDB | MCU on Eclipse  (is for Linux, but the same applies to Windows).
I hope this helps,
Erich
1,559件の閲覧回数
rob4
hi Erich,
The tutorial you referenced (I see you wrote it) discusses the SEGGER J-LINK  and the P&E Multilink, but I'm using the Redlink server  (or Link Server, or whatever it's called--it's the debugger connection via the Debug USB port).
I can restart the Redlink server via the IDE.
redlink> quit
[Closed]
[Started server]
[Connected on port 3025]
and it says [Connected on port 3025].  I can check port 3025:
$ lsof -i :3025
COMMAND     PID USER   FD   TYPE             DEVICE SIZE/OFF NODE NAME
mcuxpress 55346  ryu   43u  IPv6 0x6b3235d17ccf19ad      0t0  TCP localhost:52087->localhost:arepa-raft (ESTABLISHED)
redlinkse 77224  ryu   15u  IPv6 0x6b3235d17ccf252d      0t0  TCP localhost:arepa-raft->localhost:52087 (ESTABLISHED)
but then I start up arm-none-eabi-gdb from the command line and try
target remote localhost:3025
and gdb eventually times out without connecting.  Any ideas on how to proceed?
thanks
-Rob
1,559件の閲覧回数
converse
This may help:
How to use the command line with redlinkserv to enable gdb?
Note that its states:
redlinkserv is NOT a gdbserver and it cannot be used as one.
1,559件の閲覧回数
rob4
Thanks Con Verse - that's a helpful link! I'll investigate.
I don't require a gdbserver--I just want to debug the board via gdb outside the IDE, which is clearly feasible because the IDE itself does it.
1,559件の閲覧回数
ErichStyger
Hi Rob,
I only have used it with P&E and J-Link, have not tried RedLink for this.
Erich
