Sporadic debug launch issues after upgrade
次の代わりに検索
617件の閲覧回数
alannilsson
I have recently upgraded from 10.2 to 11.1.1.  Since then I am now sporadically seeing the following error when I try to launch a debug session:
following reset read of core registers failed - Ep(08). Cannot access core regs when target running.
Target error from Commit Flash write: Ep(08). Cannot access core regs when target running.
I cannot seem to find rhyme or reason, sometimes just rebuilding and retrying works, sometimes unplugging LPC links and replugging fixes it.  Other time I just have to keep trying multiple times and it will succeed.  Power cycling target has no effect.
I have never seen this until upgrading and I can't reliably figure out why I see it.  Anyone have any idea what it means and how to clear it.
4 返答(返信)
583件の閲覧回数
alannilsson
So this does the same as when I routinely quite MCUXpresso go and find redline server, kill it and relaunch the whole thing.  The fact that there is a specific button in the GUI to 'clean up' is ridiculous.  Why not just fix the server so it doesn't lock up?
594件の閲覧回数
alannilsson
This has happened on multiple projects now.  It never happened on the same projects in 10.2.
What is the 'Cleanup Debug' button do?  Whats its purpose, why is it needed?
589件の閲覧回数
ErichStyger
Senior Contributor V
Eclipse and GDB are using a client-server architecture. And it could be that the server is not terminated or blocking, making a connection not possible. The 'Clean Debug' tries to kill these processes.
See point 9 in https://mcuoneclipse.com/2014/11/03/debugging-failure-check-list-and-hints/
or https://mcuoneclipse.com/2012/06/01/killing-me-softly-zombies-and-debugger-engines/
I hope this helps,
Erich
602件の閲覧回数
How about disconnect the debugger before next time debug:
And maybe related your project, you can try to debug a simple demo project to test.
Regard,
Alice
