I am using LPC845 . From debugging and programming image using LPC-Link 2 debug probe. I have installed MCUxpresso IDE v11.5.1_7266 to connect with the board via LPC-Link 2.
I couldn't able to flash to board. I can see below the error every time.
[Started server]
[Connected on port 3025]
redlink> ProbeList
Index = 1
Manufacturer = NXP Semiconductors
Description = LPC-LINK2 CMSIS-DAP V5.361
Serial Number = C2FYEWGR
VID:PID = 1FC9:0090
Path = \\?\hid#vid_1fc9&pid_0090&mi_00#8&1ebe619d&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
redlink> ProbeStatus
Index = 1
VID:PID = 1FC9:0090
IsOpen = FALSE
WireInitialized = FALSE
WireProtocol = JTAG
CoresConfigured = FALSE
PacketSize = 1024
Reference Count = 0
HasSWV = FALSE
HasETM = FALSE
HasJTAG = TRUE
HasSWD = TRUE
Probe Type = CMSIS-DAP
Probe Reference Count = 0
redlink> ProbeList
Index = 1
VID:PID = 1FC9:0090
Index = 1
VID:PID = 1FC9:0090
IsOpen = FALSE
WireProtocol = JTAG
PacketSize = 1024
Reference Count = 0
HasSWV = FALSE
HasETM = FALSE
HasJTAG = TRUE
HasSWD = TRUE
redlink> ProbeIsOpen 1
FALSE
redlink> ProbeOpenByIndex 1
Probe Handle 1 Open
redlink> WireIsConnected 1
FALSE
redlink> WireSwdConnect 1
Error: Wire Ack Fault - target connected?
Same error. Over two LPC55S69 boards... I'm at my wits end.
I would check first the wire/connection: maybe you have it connected with wrong orientation?
Are you using your custom board or a LPC845-BRK board?
I mean that you check the connection/soldering on your board.
I have checked , it is ok.
Have you tried another debug probe, e.g. a J-Link or P&E Multilink?
Check the Vddsense pin on the SWD header: does it have 3.3V or Vdd on it?
Are you able to debug other boards with your probe with the same MCU?
Have you tried deleting the .launch and recreated it?
Other than that: I wrote a checklist here:
https://mcuoneclipse.com/2014/11/03/debugging-failure-check-list-and-hints/
I hope this helps,
Erich
I’m dropping you some threads that can be helpful for you.
Could you please take a look to them?
https://community.nxp.com/t5/Other-NXP-Products/problem-wire-ack-fault-target-connected/td-p/1399299
I hope this helps, Daniel.
I tried this but I didn't get solution.
I am getting same error.
kindly help me.
