Hello All,
I have RT1180 EVK SDK (SDK_2_12_0_MIMXRT1180-EVK) but when I try to import/install that to IDE, (v11.7.1 build 9221), it shows up an error saying "... SDK was not created for MCUXpresso IDE or IDE is not up to date. Is there a version of IDE that can load it or should I use some other IDE (Which one should I use)?
Thanks in advance
Solved! Go to Solution.
