question about function name in bootloader and relative user application
1,275 次查看
yangbo1
If two functions have the same name in the bootloader and relative user application separately(e.g. there is a funciton named "main" in the bootloader, and it exsites in user application too) , is there any error or potential risks?
Thanks for your attention!
1,271 次查看
ErichStyger
Specialist I
Hi @yangbo1 ,
no, this is not a problem. Because you are not linking the two parts with a linker: they are like separate applications from a linker point of view.
Only if you link an application and there are two conflicting symbols you will have an issue.
I hope this helps,
Erich
