LPCXpresso54628 No Meil Build *.BIN To Bootloader
spu12kimo
How do I need to burn to LPCXpresso54628 without using Meil build to * .bin through YModem file transfer protocol?
Is it OK to use only MCUXpresso IDE?
Thank
diego_charles
Hello 寶凱 李,
I suppose that you are using the AN12384  LPC5460x UART Secondary Bootloader using YModem, which illustrates
how to build your bin file using Keil IDE. To use MCUxpresso you will need to port your source files into a new project and use its tools to generate the bin file.
Diego
