uart/serial problem with ls1046ardb
722件の閲覧回数
rans
Senior Contributor I
We are using ls1046ardb, and the serial connection is received from console usb output.
The problem is that the serial does not work well (whether in Linux or uboot):
console shows the previous character so although a new character is pressed. It makes it really difficult to work with the serial. Doing ssh works just fine.
Thanks for any suggestion
649件の閲覧回数
rans
I am using linux machine,
anyway, doing load unload module cdc_acm.ko or just PC reboot , solved the issue
2 返答(返信)
673件の閲覧回数
Oswalag
Are you using a windows host computer?
650件の閲覧回数
rans
