ls1021a-iot board 5P49V5901 configuration file
1,131 次查看
tae-hyungkim
I make a new my board with ls1021a-iot design.
ls1021a-iot board has two clock generator IC.
One is 5P49V5901.
This IC needs PLL configuration programming for correct operation.
Does anyone have it?
标记 (1)
1,036 次查看
tae-hyungkim
5P49V5901B000 : null IC
5P49V5901B031 : custom pre-programmed IC.
I receive 5P49V5901B031 from IDT.
1,036 次查看
alexander_yakov
It seems this file is not a part of board design files package.
I'm communicating with factory regarding this question and will respond you in direct support case, which you already opened to NXP support team.
In the mean time I can only suggest downloading and looking "Timing Commander" software from IDT, as far as I can see it is quite easy to use and calculates everything automaticaly.
